8/13/2024 8:16 AM | |
Joined: 3/14/2008 Last visit: 9/13/2024 Posts: 2095 Rating: (936)
Hi, The block features neutral position and with the following signals, you can set the correct CtrlVx output. Is this what you mean? See a statement from the manual (print from PCS V9.1 SP2):
