10/22/2018 1:10 PM | |
Joined: 7/9/2015 Last visit: 5/3/2024 Posts: 3818 Rating: (554)
Hi, you can use the FM 350-1 via IM 153-1, IM 153-2 and IM 153-4 PN distributed in ET 200M. Please check manual of FM 350-1. In chapter 4/5 you will find informations about programming FM 350-1 Counter Function Module Installation and Parameter AssignmentRegards, Towome
11/9/2018 7:44 AM | |
Joined: 1/26/2014 Last visit: 3/19/2024 Posts: 164 Rating: (0) |
Dear Towome, I want to add in PCS7 not in step7. I am using simatic manager PCS7 V8.2 |
11/9/2018 8:17 AM | |
Joined: 1/21/2013 Last visit: 3/19/2024 Posts: 4618 Rating: (705) |
Hello, should be the same for FM350-1 Configuring the SIMATIC FM 350-2 Counter Module in SIMATIC PCS 7. |
1/26/2023 12:56 PM | |
Joined: 1/10/2023 Last visit: 4/29/2024 Posts: 1 Rating: (0) |
Hi did you come right with this and how well did the solution work, was there any latency due to the FM being on distributed I/O? |
