2/22/2019 2:26 AM | |
Posts: 2 Rating:
HI Manish, Did you check it?. I have a similar question. I have a S300 which controls the common services management for a chemical plant. and 3 PCS7 projects controling different production areas (each project with one S410). I want to cummunicate each PCS7 project with this common S300, but just OS<->S300. (I dont need communications between PLCs). Question is, if I use one PCS7 project as a master to manage the S300 program and generate DB tags and screens, how can I use and merge this information in the other 2 PCS7 projects? Thanks. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 2/25/2019 9:53:38 AMNew subject after splitting |
