2/2/2024 8:42 AM | |
Joined: 1/15/2007 Last visit: 5/29/2024 Posts: 51 Rating: (0) |
Hi is there a task to connect Grundfos CU351? wincc 7 PDL web browser control Java Applet 1. what problems may arise when connecting 2. The ability to pull crashes through this device through a script
Attachment76=.pdf (106 Downloads) |
2/8/2024 11:28 AM | |
Joined: 8/3/2009 Last visit: 5/27/2024 Posts: 12984 Rating: (1654)
Hello kulmx If you find no integrated solution you could also start an existing external Browser on the Runtime System as external program. (Perhaps this one could also help: LINK) Bye Murof |
