1/3/2011 9:34 PM | |
Joined: 9/6/2008 Last visit: 3/29/2024 Posts: 134 Rating:
Take a look at the pic . maybe help you |
http://electrotech-techblogg.blogspot.gr/ |
1/6/2011 4:36 PM | |
Posts: 2930 Rating:
Hi, if a textmessage is enabled, then it will be displayed. Date&TIME or I/O's will beshown if you have no text message enabled. Hope this helps |
1/11/2011 2:30 PM | |
Posts: 15 Rating:
Hi all, Sorry for the late reply been busy as hell but... :) Before you had a chance to reply with your example, I spent ages then I manage to work it out its just my logic thinking the flow of things have to go from left to right which they probably do just not visualy with LOGO! Soft Comfort. Remembering some of the dvd the kit and some luck I managed to get exactly what I wanted. The only problem is I am trying to get it to work out of 1 output instead of 2 outputs because I am using a for an imput 3 way rocker switch (off - on - off). I will defo have a look at your example I will upload my source. AttachmentLight control.zip (315 Downloads) |
