10/6/2007 3:05 AM | |
Posts: 1 Rating:
Both are HMI softwares, so what are the differences between them? |
10/6/2007 11:36 AM | |
Posts: 101 Rating:
Hi, Check for the differences below. http://www.automation.siemens.com/hmi/h … /index.htm http://www.automation.siemens.com/hmi/h … /index.htm WinCC is pre-equipped and requires SQL Server, supports redundancy on interfaces, dbs, used for SCADA // |
1/5/2018 11:13 AM | |
Joined: 9/1/2005 Last visit: 7/9/2024 Posts: 4101 Rating:
New question published by EduardoG is split to a separate thread with the subject Is WinCC (TIA Portal) the successor of WinCC flexible?. Best regards |
