6/6/2014 7:32 AM | |
Joined: 3/21/2006 Last visit: 11/1/2024 Posts: 10229 Rating: (1181) |
LED error displays with H-CPUs |
11/18/2014 11:26 PM | |
Posts: 5 Rating: (0) |
What is IFM1F |
11/19/2014 6:04 AM | |
Joined: 1/28/2009 Last visit: 10/26/2024 Posts: 6852 Rating: (1365)
Hello PravinKumar, It is explained in "LED error displays with H-CPUs" with a great details.Each S7-400H redundant system consists of 4 sync modules and 2 optic fiber cables. IFM1F indicate the Status of first sync. module assembly and associated cable .In case of any interruption in the data transfer in fiber optic cable, removing the cables,IFM1F lits in both CPUs plus REDF (flashing RUN and STOP indicates CPU is in error-search mode).In case of faulty sync module, LED IFM1F will lit in the corresponding CPU(CPU in rack#0 or in rack#1).
Same applies for the 2nd pair that "IFM2F" indicates more.Check the attachment and also page related to "5.1 Operator controls and display elements of the CPUs " in the following manual: SIMATIC High-availability systems S7-400H I hope this helps, Hamid Hosseini AttachmentH-CPU_LEDS.zip (974 Downloads) |
11/19/2014 6:47 PM | |
Hi hdhosseini, Thank u very much for your clear explanations |
7/15/2019 3:50 PM | |
Posts: 1 Rating: (0) |
Hello hdhosseini Can you share step by step of troubleshooting for this alarm..?? Because now, we got same problem in our factory. Thanks and regards
1/8/2022 1:29 AM | |
Joined: 9/27/2006 Last visit: 11/18/2024 Posts: 12296 Rating: (2691)
Hello A.jlm; The S7-400H manual has a section on "Failure and replacement of a synchronization module or fiber-optic cable": https://support.industry.siemens.com/cs/ww/en/view/82478488/39435432459 You should examine the suggested procedure, check if you hav followed all the steps and recpmmendations when you replaced the synchronization modules an the fiber -optic cable. Hope this helps, |
1/8/2022 9:50 AM | |
Joined: 1/7/2022 Last visit: 1/8/2022 Posts: 3 Rating: (0) |
