8/30/2021 10:34 AM | |
Joined: 5/16/2018 Last visit: 1/17/2024 Posts: 30 Rating: (0) |
Thank you ! :) What is the best way to upload data from some DB`s? Is best/correct way to open the offline project and use the "online" funcion (see attached), and then sleect the DB`s you want to update offline and right click and chocie "upload". then go offline again. Then will the selected DB offline be indentical to online when it comes to data? Thank you all. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 09/08/2021 11:54:49New subject after splitting |
8/31/2021 1:25 AM | |
Joined: 9/1/2017 Last visit: 10/9/2024 Posts: 156 Rating: (19) |
Hi
How can you back up the actual values of DBs and markers?(classic step7) Also may readback function in cfc programming will be interesting for you. Hope this helps |
