11/7/2017 8:43 AM | |
Posts: 20 Rating:
Dear Sirs what is the difference between format or reset for s7-300 micro memory card MMC? I am waiting for your response with best regards. Basim ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/7/2017 9:04:48 AMNew subject after splitting |
11/7/2017 8:56 AM | |
Joined: 5/28/2008 Last visit: 8/6/2024 Posts: 4515 Rating:
Hello, It is not possible for users to format a SIMATIC Micro Memory Card (MMC). All you can do is "reset" an MMC, which deletes all user data. If you formated a MMC, it will be deffected immediatly. Reset MMC means delete the user date downloaded to it. This can be done if you follow procedure mentioned in the following link: How do you reset a SIMATIC S7-300 CPU and MMC (default reset or overall reset)? Hope this helps. |
Last edited by: Ayman Elotaify at: 11/7/2017 8:56:48 AMLast edited by: Ayman Elotaify at: 11/7/2017 8:59:15 AMAyman Elotaify |
