6/9/2021 11:33 AM | |
Joined: 5/16/2008 Last visit: 3/28/2022 Posts: 9 Rating:
Dear Forum members, Does any one know what the difference is between maintenance demand / required ? Best Regards Sander |
6/10/2021 2:39 PM | |
Joined: 3/11/2019 Last visit: 7/9/2024 Posts: 1511 Rating:
Dear SANSI, maintenance demand and required is a PROFINET function. Some more details can be found in the PROFINET discription. maybe this helps SIMATIC PROFINET PROFINET with STEP 7 -Extended maintenance concept-Maintanance demanded / required"A "Maintenance required" system message can be defined for different wear parameters and an inspection of a component can be recommended, for example, when a certain number of operating hours has elapsed. The "Maintenance demanded" alarm is sent when the part involved needs to be replaced within a foreseeable period. (Example printer: The maintenance demanded alarm is sent when the ink/printer cartridges have to be replaced immediately.)" regards sancruz |
Last edited by: sancruz at: 06/10/2021 14:39:45Feedback appreciated, please rate |
