3/8/2023 8:38 PM | |
Joined: 2/15/2022 Last visit: 3/8/2023 Posts: 1 Rating: (0) |
hello I need help with my software, when applying a text the software closes, losing all my programming day, I uninstalled it, erased all the application data and nothing fixes this problem ------------------------------------------------------------------------------------------ |
Last edited by: andresg8840 at: 03/08/2023 20:44:57Last edited by: Jen_Moderator at: 03/09/2023 04:56:48New subject after splitting Last edited by: Jen_Moderator at: 03/09/2023 04:57:59Text formatting optimized. |
3/9/2023 7:08 AM | |
Joined: 1/21/2013 Last visit: 10/14/2024 Posts: 3177 Rating: (492)
Hi andresg8840, Is it a general problem or is it specific to a particular project? If the latter, your project is broken and needs to be fixed. This is not an easy process if you are doing it yourself. My advice would be to create a new support request. Kind regards |
3/9/2023 2:45 PM | |
Joined: 7/7/2010 Last visit: 10/14/2024 Posts: 15306 Rating: (2427)
What version of TIA Portal? What service pack and update are installed or applied? Have you used the TIA Software Updater to get your version of TIA Portal as up to date as possible? As far as losing work, very early in V12 and below, I routinely performed "Save As" operations to save my work as a new project - how often you may be thinking... if I just finished something that has a high expectation of success and I did not want to do that work again if Portal crashed and I had not yet downloaded those changes to a physical PLC.
science guy |
