7/2/2013 5:45 AM | |
Posts: 691 Rating: (36) |
Hello RetroK Please explain what are the objects present in that Pdl. Does it always happen when you open or create a new Pdl? Are you trying to open any older version Project in the Current WinCC V7.0 SP3? Please explain in details. |
7/2/2013 12:14 PM | |
Joined: 10/3/2010 Last visit: 4/29/2024 Posts: 1552 Rating: (188) |
RetroK, the jpg that you attached speaks for itself, open file c:\program files\siemens\wincc\diagnose\rcl_0002.txt and you'll see a list of objects with the same name. All objects before the last one of the list should be renamed. Or you check all names of your objects in the screen and try to rename manually. You could also post your picture as attachment here, so others can try to check your picture for related errors. |
B r g d s , |
7/4/2013 2:19 PM | |
One more thing, do you have the latest update installed for your version? Latest update is Update 5 for WinCC V7.0 SP3 und WinCC V7.0 SP3 ASIA I remember a similar issue getting fixed by update 5 for V7.0 SP2. As noticed a few times before, sometimes issues fixed for V7.0 SP2 can be an issue again in V7.0 SP3. |
B r g d s , |
