7/19/2017 10:35 AM | |
Posts: 7 Rating: (0) |
Hi, When I try to bitbake a get the following ERROR thrown.
regards
Last edited by: Jen_Moderator at: 7/21/2017 11:19:25 AMNew subject after splitting |
7/19/2017 12:37 PM | |
Joined: 4/28/2015 Last visit: 4/21/2024 Posts: 578 Rating: (43) |
You are building a customized image. Does building the vanilla image work? If yes, can you share the customizations that break this? We do you get OpenJDK from? meta-java? Using the right branch of that layer? Regarding customizations: We recommend to express them via kas configuration files now. Look at https://github.com/siemens/meta-iot2000/blob/jan/go-docker/meta-iot2000-example/kas-with-docker.yml, it's in-tree, but it may provide an idea how to use kas for deriving from a layer like meta-iot2000. Further infos on kas can be found at https://github.com/siemens/kas, kas-enabled meta-iot2000 is in https://github.com/siemens/meta-iot2000/commits/jan/staging. |
