9/16/2015 2:08 PM | |
Posts: 1 Rating: (0) |
Hello, I got a problem, when remove the memory card from a S7-300, the CPU is working fine. But when install the memorycard i get an SF. Anybody fimiliar with this problem? ------------------------------------------------------------------------------------------ |
Last edited by: CS Moderator at: 9/17/2015 11:29:48 AMNew subject after splitting |
9/17/2015 11:51 AM | |
Joined: 7/9/2015 Last visit: 8/30/2024 Posts: 3943 Rating: (584) |
Hi,
is the memory card a new one or was it working in another PLC? --> ift it´s not new, you should delete Files / Format with Step7 USB Prommer or PG.
Look to this FAQ to check if MMC is defect: How do you reset a SIMATIC S7-300 CPU and MMC (default reset or overall reset)? https://support.industry.siemens.com/cs/de/en/view/29801950
Towome |
2/22/2016 4:33 PM | |
Posts: 2 Rating: (1) |
try to use new memory card SF will be resolved |
2/23/2016 10:48 AM | |
Joined: 4/23/2010 Last visit: 12/31/2023 Posts: 8092 Rating: (877) |
Hello nabeelo, Please check the date of post you replied. |
7/28/2016 2:58 AM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4767 Rating: (123) |
New question published by Tanzeal is split to a separate thread with the subject 315-2pndp, BF is blinking. Best regards |
