3/19/2019 1:29 PM | |
Joined: 6/29/2018 Last visit: 4/24/2024 Posts: 17 Rating:
Hello, I want to create DCC charts for an existing project in STARTER, but when I select Control_Unit-Insert DCC chart I receive the error:No valid license key found.The application will be closed. I already did the Setup for DCC Thank you ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 3/19/2019 1:52:52 PMNew subject after splitting |
3/19/2019 1:37 PM | |
Joined: 5/12/2006 Last visit: 7/11/2024 Posts: 22308 Rating:
hello, do you have installed a CFC licence on the system. this is need for create a dcc chart. regards christoph |
3/19/2019 2:02 PM | |
Joined: 10/11/2006 Last visit: 7/12/2024 Posts: 5874 Rating:
Hello, a license for SINAMICS DCC engineering is required (CFC for SINAMICS): https://support.industry.siemens.com/cs/ww/en/view/109762889 If you have no license to be upgraded, the full license (article number 6AU1810-1HA33-0XA0) is recommended. |
With best regards, |
