9/24/2021 4:34 PM | |
Posts: 257 Rating:
Hello Forum User, Some are probably wondering where to find the Safety Evaluation Tool (SET) now? It has been fully integrated into the TIA Selection Tool. It is located in the "Safety Evaluation" area within the project view (see screenshot). We would like to combine all selection tools in the TIA Selection Tool. The advantage of this is that all products can then be selected conveniently. Today, it is already possible to select all SIMATIC, network technology, switchgear technology and, in some cases, drive technology products directly in the TIA Selection Tool and to combine them within a plant. The TIA Selection Tool can be found at the following address. https://new.siemens.com/global/en/products/automation/topic-areas/tia/tia-selection-tool.html You can start it directly in the cloud or download it as a stand alone version (does not need to be installed, runs from the folder). Best regards. SIMATIC International Technical Support Hub |
