11/11/2007 7:53 PM | |
Posts: 3149 Rating:
Hi sorry, there is no description available and as normal PCS7-user you should not care about Windows processes.... nemo |
11/29/2007 3:55 PM | |
Posts: 1776 Rating:
HI, you can check out the Windows and WinCC Diagnostic files Search in the FAQs for WinCC Dignostic |
12/5/2007 9:35 AM | |
Joined: 9/13/2005 Last visit: 11/18/2019 Posts: 86 Rating:
Hello vadrad, as mentioned before you should use Task Manager or ProcessExplorer to figure out which process is hanging. In order to find out if the process belongs to PCS 7 software you can have a look at the process names (first 2 chars): WinCC processes start with "cc", Simatic Batch processes start with "bf" , Step7 processes start with "s7". In order to analyse problems with a PCS 7 process, you should always get in contact with the Custumer support. They will assist you with creating a memory dump of the process (using userdump.exe, see http://support.microsoft.com/?scid=kb%3Ben-us%3B241215&x=15&y=11). Thememory dump can not be analysed by You or the customer, as you do not have the source code of PCS 7 software. That means the memory dumphas to be sent in andanalysed by PCS 7 development department. |
Best Regards - Mit freundlichem Gruß - yoroshiku onegaisimasu - Sincères salutations |
