5/27/2022 9:01 PM | |
Joined: 4/28/2017 Last visit: 3/23/2024 Posts: 4 Rating: (0) |
HELLO nullizhang thank you for your response in fact the machine is from the year 2005. the hmi is with windous 98. as I said the problem is that the sinumerik 840D software does not appear on the screen when the machine is started, only the bending software has appeared, and even if I open the 840D software manually it seems to me that it does not have the usual functions found on the 840D software such as the service menu and the introduction of passwords the archive introduction menu is there, but if I press on archive introduction nothing happens. ther is photos of the hmi thank you.
Attachmentpipe bending machine.zip (502 Downloads) |
6/3/2022 5:37 AM | |
I thank you very much for your beneficial support. we finally found the NC.arc and PLC.arc archives but the problem is that if I run the MMC-sturtup program for the sinumerik 840D we do not have the STARTUP menu I only have the REF key (photos N01)? So i tried to launch other utilities (softwares) from the C:\MMC2 directory in order to find the commissioning menu window, finally I found C:\MMC2\Ib, and C:\MMC2\DINO, for passwords (SUNRISE) and \DINO to introdiuse DATA and read archive but if I want to read archive from introduction data or read startup_series archive; nothing happened and i got the message (please acknowledge confirmation request in the log window )photos N02? Now this is the situation (we can note introdiuse the archive )is ther any other solution. N.B Can i ask you about the sinumerik hidden menu after the system is booted, in the other 840D there is a hidden menu for commissioning after the system boot by pressing (3) key for example, is there that in this machine? we try it but no thing so. please help for the seconde time and thank you.
Attachmentphotos 1,2.zip (483 Downloads) |
6/3/2022 3:56 PM | |
Hello #1 No we didn't do that before it's the first time, machine breken-down. #2 see pictures of the NCU lED , we have already reset PLC and NC with S4 and S3 procedure. #3 the machine OEM sent us the NC and PLC archive but we stil c'ant introduce it if we try this no thing hapend and ther is the message (please acknowledge confirmation request in the log window ) in franch photos N02? #4 we are in contact with the machine OEM to get haw to introduce data. #5 we are from algeria this is way the machine menu is in french thank you
Attachmentphotos NCU.zip (546 Downloads) |
