11/13/2021 10:22 PM | |
Joined: 2/8/2021 Last visit: 12/5/2023 Posts: 30 Rating:
And what is the difference between running the application on a 1515T and a 1511T? Rotary Knife lib: https://support.industry.siemens.com/cs/ww/en/view/109757260 Thanks! |
11/15/2021 10:57 AM | |
Joined: 11/4/2011 Last visit: 4/2/2025 Posts: 263 Rating:
The smaller the number (1511, 1513, etc.), the cheaper it is. But also: the smaller the number, the slower and less memory the PLC has. Just check the technical data of the PLCs here in SIOS, you'll see the difference right away. Also take care about the amount of technology objects the PLC can handle regarding memory, this can be seen almost at the end of the technical data. Regards, |
To explore the new Forum, you can follow the textbox in the right column, which will lead you to the corresponding page in the new Forum. Alternatively, you can start from the main page by following this link:
https://sieportal.siemens.com/en-ww/support/forum
In the coming days, we will update the configuration step by step, so that you are directed to the new Forum by default. The “classic Forum” will remain available for all known functionalities alongside the new one.
We are thrilled to finally share the future of our Forum with you. Thank you for your commitment!
Kind regards,
the Forum Support Team
