5/8/2022 10:13 AM | |
Joined: 2/15/2019 Last visit: 8/31/2024 Posts: 16 Rating:
Hello! You must create a double integer on the corresponding address range. There is no trap :) |
5/8/2022 3:32 PM | |
Joined: 9/27/2006 Last visit: 9/10/2024 Posts: 12282 Rating:
Hello pfuser; You do not mention the CPU you will be using, or over which the network you are communicating with the encoder. We can assume you are using TIA Portal in your application, from your screenshot, but we have no idea which version you are programming with. Please give us as much information on your project as you can, with more details we can probalbly provide better answers. This application example shows how to set save position and speed using a CPU 1516F-3 PN/DP Safety PLC (F-CPU) and a TR-Electronic CDV75M – EPN + FS encoder over Profinet. This looks like it could give you useful hints for your project: - Safety position, standstill, direction and speed detection https://support.industry.siemens.com/cs/ww/en/view/49221879 Hope this helps, Daniel Chartier |
