3/23/2016 1:01 PM | |
Joined: 3/7/2016 Last visit: 4/14/2022 Posts: 7 Rating:
I want to start PLC progrmaing with Step-7 PLC. Would you like to guide me which PLC should i purchased as a starter. I was thinking to purchase S-7 1200 series and one KTP700 Basic panel. So i can also practise WinCC also. Please advice!! ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 3/23/2016 2:32:17 PMNew subject after splitting |
3/23/2016 2:12 PM | |
hi Ahsan, Starter-Kits are available for every PLC-type. I think it belongs to what you want to do, like what programming language you use. For example S7-1200 does not support STL. If you don´t know what you want to have for beginning programming, I think S7-1200 would be the easiest system. with KTP700 this Starter Kit is available: SIMATIC S7-1200+KTP700 BASIC STARTER KIThope this helps, regards, |
FCK WAR! |
3/23/2016 3:18 PM | |
Joined: 7/9/2015 Last visit: 7/29/2024 Posts: 3900 Rating:
Hi, if you want only make some first programming tests you can download Step7 Trial with PLC Sim. As a registered customer you can download the Trial for SIMATIC STEP 7 Basic and Professional V13 and test it for 21 days. SIMATIC STEP 7 (TIA Portal) V13 TRIAL Download But mopS04 is right - a Starter Kit for S7-1200 is certainly not wrong. Regards, Towome |
4/6/2016 4:56 PM | |
Joined: 5/28/2008 Last visit: 7/23/2024 Posts: 4514 Rating:
Hello, You can start with the S7-155 kit. And I think you will save a considerable ammount of money if you ordered it. Hope it helps. |
Ayman Elotaify |
4/15/2016 7:15 AM | |
Joined: 11/18/2010 Last visit: 8/5/2022 Posts: 523 Rating:
please find attached siemens automation material ,which i have purchased with my hard-earned money first time ,it includes all basic PLC-HMI-WINCC-DRIVE communication having DI/DO/AI/AO best to start learning i have prepared this list after many search . viral |
4/24/2016 12:35 PM | |
Posts: 487 Rating:
Hi You will also need to look at the cost of the software .. or should I say the cost of licenses Eric |
