5/14/2008 2:14 PM | |
Posts: 64 Rating:
Hello Woedie, Onyour installed ES under startbutton ->all programs/SIMATIC/Documentation/English there is the manual PCS7-OS-Process Control, which contains your anwsers. If you do not have an ES.. https://support.automation.siemens.com/WW/skm/frameset.asp?url=%2FWW%2Fllisapi%2Edll%2F27002683%3Ffunc%3Dll%26objId%3D27002683%26objaction%3Dcsopen%26siteid%3Dcseus%26skm%3D1%26lang%3Den%26query%3DPCS7%252DOS%2BProcess%2BControl%26ehbid%3Dhtml%255F76%252Fehb%252F27002683%252Ehtm%26nodeid%3D&Query=PCS7%2DOS+Process+Control&SearchArea=hb&id=27002683&F11Marker=true&siteid=cseus&query2=&modelled=&lang=en will direct you to the documentation. Kind regards, Burnett |
