5/27/2024 12:13 PM | |
Joined: 5/25/2010 Last visit: 10/30/2024 Posts: 33 Rating: (6) |
Hi [snip] New question : I've set my prefered language . Why the hell it keep asking for other language update? I'm Speaking about thatr awfull TIA Admin. They split my question from an other thread... ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 05/28/2024 07:00:05New subject after splitting Last edited by: Jen_Moderator at: 05/28/2024 07:01:05Division of questions into separate topics. Last edited by: D. Fort at: 06/18/2024 14:38:49 |
7/8/2024 3:47 PM | |
Hi Nobody can help? I'm using french language, but TIA keep asking for spanish italian and more. That's boring. M |
7/8/2024 4:39 PM | |
Joined: 7/7/2010 Last visit: 11/8/2024 Posts: 15388 Rating: (2443)
Try a repair of your installation to update the installed languages. I recommend at least the following: English (for obvious reasons) And then add French for your install. Be sure and not check Spanish / Italian unless you intend on deploying projects for Spanish and / or Italian customers / operators / technicians / engineers. Be sure and set your project's default language and then set the HMI's default language and a way to switch languages at runtime to French & [English and/or German]. So many painful problems seem to pop up when either English or German is not also deployed to portal projects (PLC / HMI). If you need to fill in some translations, check out the TIA Translation Tool
science guy |
7/8/2024 4:42 PM | |
I ignore available language updates for languages I have not installed in tia portal. [Wishlist] TIA Admin check for installed / configured languages. Then maybe it can split language updates: [Installed Language Updates Available] {Expanded by default}
science guy |
