3/26/2020 12:10 PM | |
Joined: 12/9/2010 Last visit: 10/8/2022 Posts: 623 Rating: (77) |
Hi Sena95, While initiating HW configuration, station type needs to be specified. U insert H station for H CPU & 400 station for standard CPU. Replace function will not be possible for your case. However, u can copy program blocks to new hardware configuration. Communication functions with redundant connections and/or CPU diagnostics etc will not work. |
If you like the comment, rate it (right top) or thank it (left bottom). |
