5/26/2021 3:19 PM | |
Joined: 10/10/2005 Last visit: 7/24/2024 Posts: 1917 Rating:
Hello Benesd, the reason for this performance could be the viren scanner. After installing of STEP 7 V5.6 check also the versions of installed viren scanner on your PC. The following viren scanner are compatible with STEP 7 V5.6:
See also the information of the FAQ: How can you improve the performance in the SIMATIC Manager and in the STEP 7 project? With best regards |
7/4/2023 12:47 PM | |
Joined: 6/8/2020 Last visit: 8/1/2024 Posts: 1 Rating:
I have the same problem. Any news on how to fix? |
10/30/2023 7:53 AM | |
Joined: 8/8/2023 Last visit: 12/20/2023 Posts: 1 Rating:
Same issue, tried many things without any joy. Has there been a solution? |
