9/27/2020 10:56 AM | |
Joined: 3/22/2016 Last visit: 5/17/2024 Posts: 20 Rating: (0) |
ADAPT in the firmware of 3.5.1 and 3.5.2 requires a license, why some PXC24.2-EF32.A comes with a license, and some don’t? In order to use ADAPT, the ADAPT license needs to be purchased separately or the PXC firmware version is reduced to 3.4. Field panel: 7014 ID_STRING: PXC24.2-EF32.A200320GA00206 Application Name = ADAPT License = Not Installed Application Limit = None Expired = NO Tasks Attached = 1 Application Name = Distribution License Line 1: = DEFAULT Distribution_0 siemenssbt 1.0 permanent uncounted 111111111 HOSTID=ID_STRING=PXC24.2-EF32.A200320GA00206 Application Limit = None Expired = NO Tasks Attached = 1 Field panel: 7013 ID_STRING: PXC24.2-EF32.A170912FA10409 Application Name = ADAPT License Line 1: = DEFAULT ADAPT siemenssbt 1.0 permanent uncounted 111111111 HOSTID=ID_STRING=PXC24.2-EF32.A170912FA10409 Application Limit = None Expired = NO Tasks Attached = 1 Application Name = Distribution License Line 1: = DEFAULT Distribution_0 siemenssbt 1.0 permanent uncounted 111111111 HOSTID=ID_STRING=PXC24.2-EF32.A170912FA10409 Application Limit = None Expired = NO Tasks Attached = 1 Application Name = FLNNode License Line 1: = DEFAULT FLNNode_254 siemenssbt 1.0 permanent uncounted 111111111 HOSTID=ID_STRING=PXC24.2-EF32.A170912FA10409 Application Limit = 254 Expired = NO Tasks Attached = 2 ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 09/28/2020 13:19:55New subject after splitting |
