6/18/2008 2:34 PM | |
Posts: 42 Rating:
Angus, do you need further instructions or screenshoot. You never came back to confirm. Thanks Torpedo1215a, for confirmation. Markus |
7/2/2008 3:57 AM | |
Joined: 9/6/2007 Last visit: 7/22/2024 Posts: 81 Rating:
7/2/2008 8:55 AM | |
Posts: 5 Rating:
Hi --> No, we use the same code. Are other Devices also on the Profibus an does the other Devices work fine? --->Yes,if we use 420,everything is ok,chenge to 427B it's will be fail.
How to you unplug the USB Stick, does you deactivate the hardware bevor you pull the USB Stick? ---> just plug & play,and we use USB stick and USB CD-ROM, the resilt is the same!!
--->The remp is not key issue,because we test in office not outsite,and we test 2 pices Microbox 427B.
--->We test 2 pices Microbox 427B,and 420,the result is the same. (p.s. the 427B is new order )
Attachment12345.zip (306 Downloads) |
