1/15/2014 8:02 AM | |
Posts: 17 Rating: (0) |
Dearbigfoot, In our plant we have as same situation, as author's was started this threat. We have Microbox 427C: Hardware: - Intel Core 2 Duo CPU - 2Gb Ram - CP5613A2 - 3 pcs - CP1616 Software: - MS Windows XP Embedded Standard SP3; - WinAC (WinLC v4.6); - Simatic NET v7.1 + SP4; - WinCC , 2008; problem is we left IPC working for a day. When we came next day, the IPC was not responsible: the screen was freezed, no respond of mouse movement or click of any button on keyboard. Unfreezed the IPC is restarting the system by switch (as you know on new models of Microboxes there's switch, on old types was only plug for 24v - ok, doesn't metter). After, we recognized that 2 of 3 profibus cards are removed or disappeared or switched (I don't know how to describe it correctly) in fact instaed of 3 card in Device Manger was only 1 profibus card. (here applied screen of removed card) What can de reason of such strange situaion? Why does it happen? P.S. EWF manager was disabled on both drives (c:/ and d:/). Thank you. |
Last edited by: GrasserF at: 1/24/2014 8:13 PMnew subject after splitting from /tf/WW/en/Posts/95881 |
