5/19/2011 1:42 PM | |
Posts: 1776 Rating: (95)
Description can be found here http://support.automation.siemens.com/WW/view/en/37436598 |
5/20/2011 8:17 AM | |
Joined: 10/3/2010 Last visit: 9/30/2024 Posts: 1562 Rating: (192) |
Excel 2007 can do some strange things with add-ins. Maybe you can find some hints here: [code]http://www.breezetree.com/blog/index.php/excel-2007-add-ins-qat/[/code] |
B r g d s , |
5/20/2011 1:36 PM | |
or How can you make the menu item "WinCC" visible again in MS Excel when using the "WinCC Configuration Tool"? |
B r g d s , |
5/23/2011 7:41 AM | |
is it possible that VBA is not installed or disabled? http://support.microsoft.com/kb/287567 http://support.microsoft.com/kb/281953 http://support.microsoft.com/kb/282847 |
Last edited by: SteBo at: 5/23/2011 7:53 AM<b>Remember that Visual Basic for Applications is disabled by default in Excel 2007 !!! </b> B r g d s , |
5/23/2011 1:46 PM | |
I don't have a PC here right now with Excel 2007 & WinCC installed, so I can't give you a screenshot. You know there's also a way to reset the 2007 Ribbon - look to default bars (just google for that), maybe it helps to see it where it used be in older Office versions |
B r g d s , |
