5/4/2011 6:18 AM | |
Joined: 3/31/2009 Last visit: 7/16/2024 Posts: 191 Rating: (3) |
Dear Forum, i created a tested system for tag logging.. on wincc, there's only have 2 process tag. i create archive using wizard, and choose process value archive and select both process tag.. on my screen, i put 2 i/o field for process tag and OnlineTableControl which display archive data i run the system, both tag received data from automation system, and display current values as a change the values, but why the archive process seem not running ( no data is displayed ) and on connection icon it say 'no data connection could be established' attached is my tag logging configuration and runtime (taglogging2.jpg ) i already read the wincc manual and follow step, still wont work.. please help me.. br rusli
Attachmenttaglogging.zip (294 Downloads) |
9/11/2015 8:49 AM | |
Joined: 4/28/2009 Last visit: 6/24/2022 Posts: 24 Rating: (0) |
I checked task manager and archive manager folders, they seem OK, the photos are attached could you please check them.Thanks.
Attachmentwincc.zip (286 Downloads) |
9/14/2015 10:46 AM | |
Hello, I checked the properties of WinCCOnline Trend control, the photos are attached. I realized that on the other PC which the trends are running, there is one more running process called "CCArchiveConnMon" in task manager. The problem can be about this? In the runtime window the trend control bar has stop button, I push it and the "go" button does not appear when trend stops. I opened SQL management studio but I am not familiar with SQL server, do not know how to check archive values. Thanks. Attachmentwincc.zip (273 Downloads) |
