4/9/2018 8:55 PM | |
Joined: 3/9/2018 Last visit: 3/25/2024 Posts: 4 Rating: (0) |
Buenas tardes, quiero comunicar WinCC 7.4 RT con un SAI por SNMP, ¿Es necesasrio algun addons?. Muchas Gracias |
4/10/2018 12:34 PM | |
Joined: 9/27/2006 Last visit: 6/7/2024 Posts: 12260 Rating: (2670) |
Hola Miguel; Como hay muchos miembros en este foro que no hablan espagnol, hemos decidido usar el ingles como idioma internacional. Por favor escribanos en ingles a tu proxima visita. Ademas, explicanos bien los elementos de tu proyecto si quieres ayuda precisa. Por ejemple, para mi un SAI es un tipo de espada japonesa sin filo; tienes que decirnos con que trabajas si quieres que te endendemos mejor. Hello Miguel; Simce many members on this forum do not speak Spanish, we have decided to use English as an international langiage. Please write to us in English on your next visit. Also, take the time to describe the equipment you are working with in your project. For example, in my mind a SAI is an unsharpend japanese blade; you have to tell us what you qre working with if you want better help. Hope this helps, Daniel Chartier Edit: SNMP is a network management tool, it is used to monitor network devices over Ethernet and report on their status. It is not used to "communicate" between WinCC and a network node. Have a look at this application note that describes functions of WinCC v7.x that use SNMP: Diagnostic of SIMATIC IPCs (with IPC DiagBase, IPC DiagMonitor, WinCC (TIA Portal) or WinCC V7) https://support.industry.siemens.com/cs/ww/en/view/109478242 Hope tthis helps, DC |
