8/12/2019 6:32 AM | |
Posts: 5 Rating:
Dear experts, I have a project on WinCC7.5 which required using Web Navigator option so that 3 pc clients can connect server. After doing Web Publisher and Configurator, and adjust IE setting, on PC client, I cannot open the website WebNavigator. After IE show "Connecting to server", then it hangs on "No connecting to server". (see attached picture) I also use WinCC RT on the client to open website WebNavigator. It is as same as using IE, hang on "No connecting to server" On Server, I use Internet Explorer to open the website. It show that "Connecting to server"-->"Loading Pictures"-->"Done". IE can load website successfully. I also check IIS on server, the website already exist. I check the connection between client and sever by "Ping" and "Telnet" command. All are good. The client can connect to server via their IP and port 80. I checked in "Automation License Manager", the server already has WebNavigator License for 3 clients. In FireWall, I also created Inbound Rules and Outbound Rules which allow all port go through. The OS is Window Server 2016 Standard and browser is IE11 Could you please advised me how to solve this issue? What is wrong here? Thank all for your help. AttachmentNo connection to server.zip (721 Downloads) |
8/13/2019 6:02 AM | |
Posts: 5 Rating:
Hi Berghof, Thank for your help, Attached file are images on web client and also on web server (one account running). Hope to get your advices. Regards Huynhtuan Attachment192.168.1.20status.zip (954 Downloads) |
8/13/2019 1:56 PM | |
Posts: 5 Rating:
Hi Berghof, Thank for your help again, I have uninstalled the "Web Diagnostic Client". Then, On the server, the IE browser open the website, the http://192.168.1.20/status.html show one "Connected Web Navigator Client". (attached picture). However, the client cannot open the web, still show "no connection to server". Could you please advice me more Regards Huynh Tuan Attachment192.168.1.20status.zip (563 Downloads) |
