2/6/2024 11:12 AM | |
Joined: 5/6/2022 Last visit: 6/6/2024 Posts: 420 Rating: (83) |
Hi NIzGood, Could you share with us a screenshot of the exact build version of Windows 11 that you have installed? To rule out compatibility problems. Also, I recommend that you try a new and simple project to see if the same thing happens to you, could you check it? Best regards! |
2/7/2024 4:58 AM | |
Joined: 1/28/2023 Last visit: 5/21/2024 Posts: 20 Rating: (0) |
Hello, I tried with new projects but the same problem occurs. I'm sharing the winver screenshot. Regards ! |
