5/14/2021 11:19 AM | |
Joined: 5/16/2014 Last visit: 9/12/2022 Posts: 7298 Rating:
Hello STEP7, inside the WinCC-Runtime you can only use VBS, see the manual: https://support.industry.siemens.com/cs/ww/en/view/109762744/102595739915 Regards Georg Berghof |
Last edited by: bg2492 at: 05/14/2021 11:19:56PS: If this post did really help you, you may use the Rate-button |
5/16/2021 3:32 PM | |
Joined: 9/19/2009 Last visit: 7/5/2024 Posts: 459 Rating:
If my answer help you, use the Thanks or Rate Button, It is free of charge :-) |
5/18/2021 7:34 AM | |
Joined: 10/3/2010 Last visit: 7/5/2024 Posts: 1556 Rating:
Another way might be to share your VBA-code and if you're lucky, someone here can try to help to create you a VBS alternative? |
B r g d s , |
5/18/2021 11:58 AM | |
Usually with a google search on VBscript +write data cloud, you can get some hints or even examples. Perhaps try this for a start:
B r g d s , |
