8/14/2024 11:50 AM | |
Joined: 8/3/2009 Last visit: 11/19/2024 Posts: 14215 Rating: (1775)
Hello AutoGen_6560500 If the both OS run, check the @RedundantServerState tags of both, which values do you see? Seems like the Redundancy is not working properly... do you see each other in Simatic Shell? Check also the information in this example: https://support.industry.siemens.com/cs/de/en/view/109772627 Bye Murof |
Last edited by: Murof at: 08/14/2024 11:50:53If this Information really helps, you could use the Rate function |
