1/8/2021 10:34 AM | |
Joined: 5/16/2014 Last visit: 9/12/2022 Posts: 7298 Rating: (2155)
Hello ashadako, you can in apdiag.exe use the menu-item "Output On Screen". see manual "WinCC V7.5 SP1: General information and installation" https://support.industry.siemens.com/cs/de/en/view/109773054/19438964619 Regards Georg Berghof |
PS: If this post did really help you, you may use the Rate-button |
1/8/2021 11:03 AM | |
Joined: 8/1/2019 Last visit: 7/9/2024 Posts: 300 Rating: (3) |
So, i opened output on screen then pressed the button in wincc runtime --> Nothing happened! The screen is still empty! |
1/8/2021 12:49 PM | |
Hello ashadako, have you startet the diagnostic with apdiag ? see manual SIMATIC HMI WinCC V7.5 SP1 WinCC Information System https://support.industry.siemens.com/cs/gb/en/view/109772961/19438908939
Georg Berghof |
1/8/2021 12:52 PM | |
Yes i did that but still no results. |
