3/30/2020 8:58 AM | |
Joined: 5/16/2014 Last visit: 9/12/2022 Posts: 7298 Rating: (2146)
Hello laurensvdm, you can read all data, independing where they are stored, if you https://support.industry.siemens.com/cs/ww/en/view/38132261 But the runtime needs always to run, when you would read the data. Regards Georg Berghof |
PS: If this post did really help you, you may use the Rate-button |
3/30/2020 9:16 AM | |
Posts: 3 Rating: (0) |
Thanks for the reply. However i know that tutorial as i used it in the past. I'm able to read the data.. The data just doesn't get added directly during RunTime .. If i open WinCC License manager it says this ; [snip] Could this affect the proper working ? |
Last edited by: Jen_Moderator at: 03/30/2020 11:14:02Removed link and added file as an attachment. |
