3/18/2015 6:36 AM | |
Joined: 11/3/2010 Last visit: 8/26/2024 Posts: 9 Rating:
Dear Sir, I would like to check with you regarding WinCC CAS connection. We are using CAS with redundant OS server configuration. The configuration is OS server can store data up to 1 month & CAS can store up to 6 month. We configured the CAS long time back and it was running fine. I checked the diagnostics file, it says that "Set remote object count" which I am not getting. Thanks & Regards, AttachmentDiagnose_Send.zip (80 Downloads) |
