6/7/2019 2:30 PM | |
Joined: 3/3/2016 Last visit: 9/30/2024 Posts: 140 Rating: (0) |
Hi! I want read the internal tag from HMI to PLC. HMI program in Wincc flexible 2008 PLC program in Simatic manager. |
6/8/2019 8:17 AM | |
yes, i used wincc flexible runtime advanced. |
6/10/2019 8:43 AM | |
I set the tag as per above instruction.I have enclosed the Print screen. |
6/10/2019 1:23 PM | |
Sir, Actually what i need Running Recipe tag taken from wincc flexible run time software. Customer select that recipe selection in wincc flexible run time , That recipe tag (IO field) is a internal tag. How to use this internal tag in Communicated PLC. AttachmentDesktop.zip (230 Downloads) |
6/11/2019 8:38 AM | |
sorry sir, I didn't understand. Can you explain with example. |
