10/19/2008 9:54 AM | |
Posts: 3 Rating: (0) |
How can I open Protool Cs Project in wincc Flexible |
10/19/2008 10:26 AM | |
Joined: 9/27/2006 Last visit: 5/11/2024 Posts: 12257 Rating: (2666) |
Hello salman; You will have to migrate the Protool project to WinCC Flexible. Here is the Migration manual for WinCC Flex 2007: http://support.automation.siemens.com/WW/view/en/18796902 Hope this helps, Daniel Chartier |
10/23/2008 3:00 PM | |
Posts: 24 Rating: (1) |
Dear salman B, You have two ways to open protool project throw wincc flexble, the first one just open the wizared of wincc flexble and choose open protool project then choose your project and step by step the programming will tell you it will convert the program from protool to wincc format. that was the first way the secound way just choose project from top par then choose open then change the formate of the file of type to .pdb finally choose your protool project from hard disk . also i attached pictures for you to guide you step by step how to make this steps. Finally i hope this information is useful for you Attachmentpic.zip (301 Downloads) |
