8/8/2014 10:38 AM | |
Joined: 1/21/2013 Last visit: 6/6/2024 Posts: 4620 Rating: (705) |
Hello saeedplc, Under Network choose PPI and under HMI Device ---> Baud rate ---> 9600 and you can use a Profibus cable between S7 200 and TP177 Take a look: What are S7-200 Programming Tips and where can I obtain them? and Which HMI components can you connect with S7-200 CPU and what should you watch out for when doing so? and What should you watch out for when setting up a connection between S7-200 and SIMATIC Panels or WinCC flexible PC Runtime and what are the options? |
8/8/2014 3:38 PM | |
Hello saeedplc, Because the S7 200 for communication use PPI Protocol S7 300/400 use MPI or PROFIBUS You can use "always" Profibus cable between PLC and HMI for PPI/MPI/DP Please havea look: PPI Cable for S7-200 to TP177 Micro comunication If can help to understand: Difference between S7-200 PPI and S7-200 MPI and SIMATIC S7-200 Communication - PLCs - Siemens |
Last edited by: Ste39 at: 8/8/2014 4:19 PMAdd Link Last edited by: Ste39 at: 8/8/2014 4:16 PMLast edited by: Ste39 at: 8/8/2014 3:51 PMAdd thread Last edited by: Ste39 at: 8/8/2014 3:42 PM |
