7/18/2024 2:24 PM | |
Joined: 7/11/2024 Last visit: 11/6/2024 Posts: 55 Rating: (5) |
Hello, First of all, I recommend you to check which OS are supported by WinCC Flexible 2008 SP5: https://support.industry.siemens.com/cs/ww/es/view/109749111/en Then, as you have the license, you can try deleting everything related with WinCC flexible and installing the Trial license. After that, you should be able to activate the license. You can download the trial here: https://support.industry.siemens.com/cs/ww/es/view/100777999 Hope it works! |
If this comment was helpful, be sure to rate it! |
