9/13/2023 8:07 AM | |
Joined: 8/3/2009 Last visit: 7/15/2024 Posts: 13293 Rating: (1686)
Hello Engr@IND WinCC Advanced RT is "freezed" in Version V17. Also in TIA Portal V18 there is only WinCC Advanced V17available. In the V18 Orderlist that is available HERE there is also only V17 available. Options are inclusive in the Upgrade packages. -> I think there will be no improvements any more with WinCC Basic/Comfort/Advanced. everything leads to WinCC Unified Bye Murof |
