12/28/2023 5:52 PM | |
Joined: 7/1/2020 Last visit: 2/10/2024 Posts: 1 Rating: (0) |
I have similar problem with "WinCC License Advanced was not found" for V17. My License is for WinCC Comfort V18. 6AV21010AA080AHS Is this not the same license? ------------------------------------------------------------------------------------------ |
Last edited by: jmedley12 at: 12/28/2023 18:07:15Last edited by: jmedley12 at: 12/28/2023 18:17:49Last edited by: Jen_Moderator at: 12/29/2023 05:03:28New subject after splitting |
12/28/2023 7:08 PM | |
Joined: 1/21/2013 Last visit: 10/15/2024 Posts: 3182 Rating: (494) |
Hi jmedley12, The licenses for WinCC in TIA Portal are downward compatible. This means that a V18 license can also be used for V17. However, you must have the correct edition for your device. With your WinCC Comfort license you can configure all panel devices (Classic and Unified). However, to configure a PC system, at least a WinCC Advanced license is required. Please refer to "Scaling of products in TIA Portal" and "Licensing STEP 7 and WinCC". Kind regards |
