11/12/2014 2:59 PM | |
Joined: 5/16/2014 Last visit: 9/12/2022 Posts: 7298 Rating: (2146)
Hello saeedplc, which version of WinCC do you use ? HResult-Errors have in most cases to do with wrong DCOM-settings See the following FAQ for details, depending on the WinCC-version: http://support.automation.siemens.com/WW/view/en/6836122 Regards Georg Berghof |
PS: If this post did really help you, you may use the Rate-button |
11/12/2014 4:15 PM | |
Posts: 288 Rating: (4) |
i use wincc version 6 i read the your mentioned link but problem isn't solved! |
11/12/2014 7:03 PM | |
Hello saeedplc, WinCCV6.0 SP4 or V6.2 SP3? The HResult-Error points to an "interface"-problem in the OS. You should check the event-logs of the OS, maybe you can find a hint there. Regards Georg Berghof |
