7/26/2016 7:06 AM | |
Posts: 5 Rating: (0) |
Hi All, I am having query for wincc RT. Two month before I commissioned one system but now customer is facing problem for Wincc RT IPC communication with PLC(CPU315-2PN/DP), all the IO fields in Wincc RT program showing ##. The connection in-between IPC and PLC is through Ethernet manage switch and communication used is profinet . The same manage switch is used to communicate customers PLC which is S7-400 series CPU. After resetting Wincc RT communication work fore some time but after some time communication stops(Customers feedback). I informed the customer to check the following. Let me know if I am correct. 1) Check whether IP address conflict 2) Check for Noise i.e. is there any high voltage power cable present near Ethernet cable? ------------------------------------------------------------------------------------------ |
Last edited by: Namdeo123 at: 7/26/2016 7:12:18 AMLast edited by: Min_Moderator at: 7/26/2016 10:29:10 AMNew subject after splitting |
3/29/2018 8:58 AM | |
Joined: 8/21/2014 Last visit: 9/27/2024 Posts: 1024 Rating: (14) |
New question published by dhaniamandeep is split to a separate thread with the subject Wincc RT Advanced 128 powertag software - IO fields showing ##". Best regards |
