4/24/2012 11:35 AM | |
Joined: 10/3/2010 Last visit: 7/31/2024 Posts: 1560 Rating: (190) |
You shouldn't have to use reset_wincc.vbs several times a day. The goal is to find the real cause:
and indeed, more feedback can help to find the cause Brgds |
B r g d s , |
4/24/2012 9:07 PM | |
so are you talking 'bout a server/client situation? in that case, both need to have the same version, inclusive the HF8. |
B r g d s , |
4/25/2012 8:14 AM | |
Posts: 291 Rating: (68) |
Hi Leffe_77, I don't know what would be the causer of your disappearance of HMI Runtime Screen. But since personally I've encountered this problem several times before, I would like to share the way I have my RT screen come back. (Mine was resulting from my OLE-Automation caller/ bad coding and so on.) To be in brief, I don't think you need to "start WinCC Explorer and deactivate runtime...". Please take a look at the situation I rebuilt as attached, and try one of the solutions inside the attachment. (Please try to excute "ReInitialize_PDLRT.vbs" first. "ReStart_Pdlrt.vbs" is just another alternative. ) Best regards, Komi AttachmentMake_RTScreen_Recovered.zip (207 Downloads) |
4/25/2012 11:18 AM | |
Posts: 4 Rating: (0) |
Not "graphic designer", runtime is disappearing. I'm waitting to receive from customer diagnose files and files will be posted here to check what is reason. |
