11/20/2020 3:03 PM | |
Posts: 39 Rating: (0) |
I found the cause; it is when I plug the PC adapter in the one of the CPUs. the HMI readings show ### So it is when I am programing! |
11/20/2020 3:16 PM | |
Joined: 4/24/2006 Last visit: 4/26/2024 Posts: 8616 Rating: (1147)
Hello, What type of CPU are you using? Can you check the Communication resources of CPU? Best regards, Wizard |
11/20/2020 3:18 PM | |
It is CPU315 2DP |
11/20/2020 5:07 PM | |
Hello, If possible, check online. Then you can see how many resources are reserved. Best regards, Wizard |
