3/15/2024 1:17 PM | |
Joined: 8/21/2014 Last visit: 5/13/2024 Posts: 954 Rating: (13) |
Hello AutoGen_3808066, Please try to discuss your question in English language. This is an internationalcommunityand we try to focus on one language. Posting in English will help you to get more response to your question. This is the translation of your question:
Best Regards, The Helping Hand |
3/15/2024 2:53 PM | |
Joined: 7/19/2022 Last visit: 5/14/2024 Posts: 358 Rating: (61) |
Hello AutoGen_3808066, WinCC already has its own SQL database to store process variable and alarm data. Still, if you want to store data in an external database you can do so. This script is available in SIOS: How do you access an SQL database in WinCC Runtime Advanced using a script? which, even if it is for WinCC Runtime Advanced, is valid since it is VB code |
