5/14/2010 10:50 AM | |
Posts: 20 Rating: (0) |
Hi all, I am trying to import tags from a PCS 7(with WinCC ver 6.2 ) project to a standalone WinCC (ver 7) project. I am using the Tag Import/ Export tool. The problem is that whenever a structure is imported, the diagnostis replies with an "invalid parameter". Tags belonging tothe structureare importedbut unusable since they do not have a parent structure. Attachmentdiag.pdf (217 Downloads) |
5/14/2010 10:52 AM | |
And here is the .VEX file: I will zip next time Attachmentimport_vex.pdf (217 Downloads) |
5/14/2010 11:55 AM | |
Joined: 1/4/2010 Last visit: 3/19/2024 Posts: 650 Rating: (40)
Hi Perhaps it works better with WinCC Configuration Tools and this FAQ? http://support.automation.siemens.com/WW/view/en/16504646 |
Regards |
